Mathcad help :(
SOLVED
Newbie
Mathcad help :(
Hello, my name is Alex and i am a student at the Polytechnic University of Bucharest.
I have never used this software before and it is getting very dificult finding what i need.
My industrial design teacher has given me some equation stuff to work, but i never used mathcad.
I have to create in mathcad 2 cylinders that would intersect and after that make some calculations.
The first is vertical and the second should passthrough the first but horizontaly, i've attached a photo, hope this will be usefull.
He explained me that there ar 3 scenarios i need to test, all based on assigning a diferent value to "d".
Please help if can
Re: Mathcad help :(
I don't know what the real needs are, either.
It looks to me as if the graph which is described is the flatprojection/unrolling of the intersection of two orthogonal cylinders of same size. d being some kind of offset. d=r meaning that the axis of the cyliniders intersect and the cylinder intersection collapsed into two ellipses which unroll to two sines. But then, i may be wrong - the formulas I came up with are slightly different from those posted.
37 REPLIES 37
Re: Mathcad help :(
Please attach a Mathcad worksheet with what you had tried so far.
What are you after? equations? 2D-plots? 3D-plots?
Re: Mathcad help :(
See attached. It should at least show you how to start.
Alan
Re: Mathcad help :(
Hello, thank you for replying so short.
The plot is 2D, i will reply as soon as i can.
I am getting a wrong format error, i am using Mathcad Prime 2.0
I must appologize, i dont know about anything about inserting radical equations.
Alex.
Re: Mathcad help :(
Here is a Prime 2 version.
Alan
Re: Mathcad help :(
Thank you Alan, thats just wow what you did there, i wish i could find a starter tutorial on mathcad
Re: Mathcad help :(
Alexandru Hera wrote:
... i wish i could find a starter tutorial on mathcad
Click on help (the question mark at the top-right of Prime 2). There is a tutorial there:
Alan
Re: Mathcad help :(
For better explaining Alan, hope you can understand exacly whan i need
the first scenario allows me to alocate multiple values to d and represent them.
Re: Mathcad help :(
Err...no!
1. What is the orientation of your 2nd cylinder? 2. What, exactly is it you are trying to calculate? Your first post suggested a number of discrete values of d. Are you now looking for a plot of y as a function of d?
I'm afraid I'll need a more detailed explanation/better drawings (make them 3D?).
Alan
Re: Mathcad help :(
Well, i am trying to calculate y based on the d value, 2d not 3d
The orientation is straight throught the first, like a nail.
