Mathcad result formatting
dm-3
I have some calculations developed in Mathcad 15. When I try to open the file, the results are not getting displayed.
If I hit Formats> Result> Unit display> Format units I can see the result.
Suggest me how to fix this problem.
I attach the files herewith.
Dhinesh
FDS
(To:dm-3)
This is because automatic calculation is not on. Go to the tools menu and put automatic calculation on. If you do not like this just hit F9 and the worksheet will calculate.
FDS
(To:dm-3)
VladimirN
24-Ruby II
(To:dm-3)
Hello!
You can also use the shortcut for calculate worksheet - "Ctrl + F9".
