How do you break an expression, so that it will print on two, (or more), lines?
Which version of Mathcad are you using?
And what's the source of the expression you are trying to break (eg, are you typing it in or is it a result)?
Stuart
Try to use a "Ctrl + Enter" combination of keys (it work's in the regular version of Mathcad, not in Prime version).
