Matrix Help
Finny
1-Newbie
Matrix Help
For a school project involving the modeling of the dynamics of a hydraulic servovalve, I need to create matrices in order to create the transfer functions for valve model.
Now when I try to make a 3x2 matrix, I need the values to be [0 0; 0 1/m; K 0].
I have modified the variables m and K to be unitless. However, I get an error with the 2nd 0 ( [0 0; 0 1/m; K 0] ), has a unit of A/m^3 although I entered 0.
Later I get an error with another matrix in which it claims that a constant is 'unitless' while everything else is '[]unitless'
Any thoughts?
Thx
Finny
4 REPLIES 4
StuartBruff
23-Emerald II
(To:Finny)
Any thoughts?
Thx
Finny
From the sound of it you have hit on the limitation that arrays need to be all of the same unit (strictly, dimension).
The solution is to put all values into the same, preferably coherent, system of units (eg, SI) and then write your worksheet in a unitless form; alternatively, use conversion constants to make all value unitless, then restore the results to the expected units.
Stuart
that is what I have been with all my variables, m, b,etc. They are all unitless when they go into the matrix. The problem however is when I put a single digit eg 0 or 1 into the matrix, for some reason mathcad automatically gives the matrix a unit even though I just want the digit.
StuartBruff
23-Emerald II
(To:Finny)
Finny,
Could you please post your worksheet (or an extract that shows the problem)?
Stuart
We can have in Mathcad **-15 vectors and matrix with unitless values or with values of one dimention (mass, time etc).
We can have vectors and matrix with values with different dimention only in Mathcad Prime.
One example (sorry - in Russian):
http://twt.mpei.ac.ru/TTHB/1/chain.1.jpg
