Maximize function - Multiple output issue.
MikeArmstrong
I am working through a simplified Pipe Stress calculation and having an issue with the Maximize function. I have tried to use the Maximize function to calculate the allowable free span of the pipeline, without success.
I am looking at the stresses in two pipelines and therefore require two results from the function. I have set up a Given/Find solve block without any issues. Can anybody explain if that a limitation of the Minimize function?
Cheers
Mike
How about the attached? Surely, sigma.s should be vectorised?
Alan
16 REPLIES 16
Mike,
From the Help file: "If you are solving for n variables, the solve block must have n equations"
Alan
I appreciate that Alan, but still this issue is driving me mad.
I have two values for sigma.c and sigma.t and I'm trying to find the maximum length that x can be (x is used for calculating the free span), so the combined longitudinal stressed do not exceed 95% yield.
M11 worksheet included.
Mike
Alan
Cheers for taking the time Alan, but the calculated lengths should be 59.3m & 57.9m
Mike
Mike
Are you sure? These are the results you obtain without vectorising sigma.s. I've vectorised sigma.s. Without vectorising the sigma.s function just returns a single value. Is that what you intended?
Alan
Positive Alan,
Using the calculated spans in your example, the spanning stress would be above the specified yield with the other expected stresses.
Mike
Sorry for the mulitple replies, the website is giving me grief.
I get the following.
Mike
Ok, in that case, the attached should do it!
(Actually, my previous file was wrong also because I forgot to put subscripts on sigma.c and sigma.t!)
Alan
Cheers Alan, nice work.
You have to admit that it looks horrible though. Maybe I'll stick with the Given/Find solve block for this issue.
Cheers
Mike
I think you should compare Wp_sub.Z^-1 with Wp_sub/Z. They're not the same!
Alan
Good spot Wayne, because I had brought the Z up, the formula required the vectorize operator.
Mike
I have changed this to be correct Alan.
Cheers to both you and Wayne for looking.
Mike
Hi Mike,
Your much too bright, try dimming it down to my level.
MikeArmstrong
(To:wayne)
Hahahahahah, stop being modest Wayne.
I am actually solving for x, I'm looking for the maximum allowable span, which I have found using a Given/Find solve block, but I can't get the Maximize solve block to work.
Mike
tmp.gifMIke,
(Thanks Alan, for how to use the solve block
My original comment was in error because I did not take the sq root to get xmax, but the point is that is easy to solve for directly. Why use a solve block?
Anyway, I get these lengths (Maybe I goofed)?
MikeArmstrong
(To:wayne)
Wayne Reid wrote:
tmp.gifMIke,
I goofed, not you Wayne.
When I submit the calculation I will transpose the formula as you have done. I was simply playing around with the Maximize function.
Cheers
Mike
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
