Mechanical engineering
Highlighted
Sapphire III
Aside from the fact that you need to define kN as a unit (kN := 10^3 N), you're off to a good start.
Now if you sum the forces to be equal to zero and sum the moments to be equal to zero, you can solve for the reactions. Shear and moments are then simply the basic static equations from school.
Fred Kohlhepp
fkohlhepp@sikorsky.com
4 REPLIES 4
Highlighted
A solution is given in the attached sheet.
regards, Ian
Highlighted
Thank you for attached sheet,but sorry it doesn't open the attached file in my computer if you post in (MCD)format.
Regards
V.Wilkstr�m
Highlighted
The original file was generated in Mathcad 13. Attached file has been saved in Mathcad 11 format.
regards
Ian
Highlighted
Thanks Ian,
It looks very nice, but I am engineer of HVAC and I need to solve in simply method.
Regards
V.Wilkstr�m
