Minerr Residual
SOLVED
Garnet
Minerr Residual
Hello All,
In the attached program, I have calculated root mean square of the residual. Could anybody check the procedure and see if I am doing this in the correct way please?
Thank you in advance.
Tags (3)
Re: Minerr Residual
RMS is Root Mean Square. What you have would be called RSS, for Root Sum Square
Re: Minerr Residual
Re: Minerr Residual
Thank you Richard.
