Missing OLE Components
Efried
1-Newbie
after deinstalling a parallel Mathcad 14 installation and registering Mathcad to Net, the converter into Prime 2.0 works but all the OLE components have gone. What are the best options I have to be productive again with both Mathcad 15 and Prime 2.0.
PS: I already have re-installed Mathcad 15 without any changes at all.
PSS: I did find some hints towards using regall.bat, but this relates to Mathcad 8, what is the procedure with Mathcad 15
many thanks
best regards
5 REPLIES 5
24-Ruby V
(To:Efried)
Normally I would say that you should run mcregister.exe in the Mathcad15 folder as Administrator, but as you wrote in another thread (http://communities.ptc.com/message/199069#199069) you already did.
Maybe it helps to find mcmreg.exe, start it and navigate to the *.mcm files in the Mathcad15/mcm folder and register them that way.
Thanks, I guess regsitering ocx is something different. May be removing
Microsoft Visual C++ 2005 Redistributable Package
caused the problem.
Would it be possibile installing the 2008 version?
thanks
24-Ruby V
(To:Efried)
You are right, my fault.
May be removing
caused the problem.
That sure will be the cause. I don't think that version 2008 will do good as the preinstallation instructions for Mathcad 15 insist on Microsoft Visual C++ 2005 Redistributable Package SP1 (x86) (otherwise they would have added: or higher). YOu can download it here: http://www.microsoft.com/downloads/de-de/details.aspx?FamilyID=200b2fd9-ae1a-4a14-984d-389c36f85647
I'm not sure but maybe you have to (re)install Mathcad after the installation of this pack.
Hope it helps.
I did the manual regsvr32 *.ocx job, and Heureka! it works
Can you please be more descriptive? I am having this same problem; controls dont work but web controls do. I tried restarting my computer, repairing, uninstalling and re-installing, I tried the "mcmreg.exe" fix from this thread:
http://communities.ptc.com/thread/33757
