Need Help: Corrupted File in Mathcad Express Prime 6.0
DP_9879889
2-Guest
Hey all,
I need some help.
I was working on a school project, finished with the days work. Saved and closed the laptop. I then remembered that i needed to fix a few things really quick. but when i tried to open the file again it pops up with the error "file type not supported"
So i would like to hear if some one can help me fix this corrupted file
BTW using a Student Version of Mathcad Prime 6.0.0.0
1 ACCEPTED SOLUTION
Thanks for trying but i were lucky that the dropbox i saved it on, had gotten a recent backup file i could revert to.
2 REPLIES 2
Unfortunately Prime is "famous" for damaging files - especially when they contain some images. We have seen a lot of complaints about this in this forum.
Attached is what I could come up with. The Prime file is missing images and the images I could save you find in the archive "images".
Maybe someone else can come up with a more satisfying restoration.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
