Need Sample Workbook on DOE using taguchi method
SOLVED
kkr-2
Regular Member
Looking for an sample how to do DOE using taguchi Method. Any case studies on automotive will do great help.
Tags (2)
1 ACCEPTED SOLUTION
Re: Need Sample Workbook on DOE using taguchi method
There's an example in the Mathcad 15 and Prime 3.1 Help: Example: Determining Optimal Conditions.
Stuart
1 REPLY 1
Stuart
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
