Need help repeating process
ptc-5105545
I want to repeat the attached process several times in a single mathcad sheet, but the inbut variables need to be different variables.
Is there an easy and quick way to do it?
Is there such a thing as a function file in MathCAD. I have used them before in another program called Matlab and they are very effective
at performing repetetive processes.
You haven't read much docs about Mathcad yet, right?
Of course there are functions in Mathcad - look if the attached would help.
Furthermore I second what Henry said - in the future please attach your worksheet. You already found out how to do as you had attached a pic.
Please attach a mathcad worksheet so other can help. What is the parameter that you want to change?
is comb and method your input variable?
Just change your program to a function of comb and method, such as
q0`(comb, method)
then you calculate the program at different value of comb and method using q0`(1,0) q0`(2,0)
