Nested if Statements
SOLVED
Re: Nested if Statements
If Cr>0.01 the first block is executed, if Cr<0.01 the second block is executed. If Cr=0.01 neither block is executed. How you deal with this depends on what you want. If you want the first block to execute when Cr=0.01 change the greater than to a greater then or equal to. If you want the second block to execute when Cr=0.01 you can either change the less than to a less than or equal to, or change it to an otherwise.
ahhh, you are correct. I misread your statement I need to change that to a less than or equal to.
Gotcha another poster pointed out the same thing. The chances of me hitting 0.01 exactly were close to zero so brute force debugging fail
I have just restructed. Looks a little more traqnsparent now (IMO)
Mike
Remember if there any chance at all it's good practice to program for it.
Mike
Good call, one less if statement cleans it up. Thanks for the help!
No problem at all.
Remember try and make the programs easy to follow. When I write anything, I aim to keep it as simple as possible, so if a non-Mathcad user wants to check my work, it's still possible.
Mike
Yes.
1-exp(-NTU(1-Cr)) / 1-Cr*(exp(-NTU*(1-Cr)))
converges to
NTU/(1+NTU)
as Cr approaches 1. I failed to see that in the original logic (but it is a good thing it is true or i would have a discontinuity in my solution)
