Suffering as a new MathCad user. Can't seem to get started on a 2 independent variable regression. If I could just see an example sheet, I think I could get moving.
Dean
Which version of Mathcad are you using?
What sort of regression do you want to do (linear, polynomial, something else)?
Thanks for answering so quickly. I really am very new at Mathcad.
Mathcad Prime 2.0.
I assume polynomial will get me a good enough result.
Dean
X1 | X2 | Y |
5 | 8.06 | 2.0944 |
5 | 20 | 2.5696 |
5 | 25 | 2.8368 |
5 | 30 | 3.0368 |
5 | 40 | 3.5184 |
5 | 50 | 4.616 |
10 | 8.06 | 6.3456 |
10 | 20 | 7.7232 |
10 | 25 | 8.4272 |
10 | 30 | 9.1168 |
10 | 40 | 10.616 |
10 | 50 | 12.2864 |
15 | 8.06 | 13.7552 |
15 | 20 | 15.456 |
15 | 25 | 16.8256 |
15 | 30 | 18.4128 |
15 | 40 | 22.3008 |
15 | 50 | 28.4224 |
20 | 8.06 | 23.4992 |
20 | 20 | 25.9152 |
20 | 25 | 27.9904 |
20 | 30 | 30.5088 |
20 | 40 | 36.4704 |
20 | 50 | 45.7856 |
25 | 8.06 | 36.1312 |
25 | 20 | 37.1184 |
25 | 25 | 41.4944 |
25 | 30 | 45.7856 |
25 | 40 | 57.872 |
25 | 50 | 72.5248 |
Thanks, RJ. Will work on this tonight. You are the man.
DB
With function:
