Newton Raphson Method Help
sunny1982
Hi I have started this, I don't know how to start this question, I haven't ever used the Newton Raphson method, the abc in my case would be 14.742. How would I go about solving this equation manually First of all?
13 REPLIES 13
MikeArmstrong
(To:sunny1982)
Are you sure you are allowed to use Mathcad?
Have you tried solving using the methods in your other thread.
Have a look at the attached and below.
No I have to use mathlab, but I need to solve it manually first
MikeArmstrong
(To:sunny1982)
That's a shame, however, have a look at my post above.
Sorry the abc is 742 not 14.14.742 but it would be 14.742. Disregard the 14 already in there.
MikeArmstrong
(To:sunny1982)
Just remove the first 14 and you have your answer.
Just to get you started. What you are supposed to do is making a table like the one below - of course you should do it manually just using your calculator.
As you can see it does not take many interation steps until the difference between successive approximations is (much) smaller than 10^-6 and so the sixth decimal does not change anymore.
You see the approximations in the last column and they are then transfered to the second column for the next iteration step.
The first thing to do in that kind of task is to plot the graph of the function to get a decent start value for the iteration. In my case I had chosen -5 on purpose but sure -6 would have been a better choice.
What would the root be if k was 742? sorry its just I have not got mathcad at home just at uni.
MikeArmstrong
(To:sunny1982)
The symbolic processor finds three solutions.
Not if you enter 14+742/1000 instead of 14*742/1000
OK it will still find three solutions but only one of them would be real.
The equation obviously is chosen on purpose so that if it ends with 14 it only has one real solution and this fact will not change if you add xxx/1000.
BTW, the equation in the sheet you posted as first reply seems to be in some crazy manner corrupted! Even if you repair the multiply by 14 error it will yield wrong results. Not sure how you managed to get this messed up that way. The equations looks pefectly OK but it acts as if you had typed an invisible pair of parentheses.
How did you do that?
MikeArmstrong
(To:Werner_E)
I wasn't too sure on the correct format so I included both.
I have no idea. I have just deleted the x and re-typed it and got the following.
Here you are:
I guess thats a case for digging your head deep into your books, your lecture notes or whatever you have and maybe even look it up in the net.
