When setting up Prime Analysis in Creo 3.0, attempting to list Prime input/output returns the error "No properly tagged Prime variables found".
Variables have been set up in a pre-existing *.mcdx file and the file loaded in the Prime Analysis set up dialogue in Creo. On the Input/Output tab of Prime, I select "Show As List" and all my variables are listed, yet the Input Selection panel in Creo remains dismally empty. Am I doing something wrong or is there a system or compatibility error?
I'm also getting a "Quality Agent 3.0 F000 from PTC has stopped working" error at various times when using MathCAD and Creo.
Quality Agent 2.0 F000 from PTC has stopped working
Problem signature:
Problem Event Name: BEX64
Application Name: qualityagent.exe
Application Version: 31.0.2012.380
Application Timestamp: 53bc27cf
Fault Module Name: qualityagent.exe
Fault Module Version: 31.0.2012.380
Fault Module Timestamp: 53bc27cf
Exception Offset: 0000000000004acd
Exception Code: c0000417
Exception Data: 0000000000000000
OS Version: 6.1.7601.2.1.0.256.48
etc...
references:
1. "Creo Parametric and Mathcad Prime 1.0 Integration (Transmission Shaft)": http://communities.ptc.com/videos/4502
2. "Creo Parametric 2.0 integration with Mathcad Prime 3.0": http://communities.ptc.com/videos/4501
Please contact with PTC's tech support by using "Mathcad Support Center", here: http://www.ptc.com/support/mathcad_supportCenter.htm
I am having this same issue, how did you solve it?
