Non-topic.
SOLVED
Highlighted
Alexandrite
Non-topic.
My question is :
Thanks in advance for your help.
Best Regards.
1 ACCEPTED SOLUTION
Re: Non-topic.
4 REPLIES 4
Re: Non-topic.
Use "simplify" from the symbolic toolbox!
If you expected 0 you should have put parantheses around the last term (2*sqrt(2))
Re: Non-topic.
The similar question:
Best Regards.
Re: Non-topic.
Re: Non-topic.
Many thanks, Werner.
Best Regards.
