None base units in mixed unit array
MikeArmstrong
I would like the ability to choose the units in a calculated mixed unit array. At the moment Mathcad Prime defaults to the standard base units and the only way around this, that I know of is shown below.
Standard Output
Desired Output
It can be done but looks untidy. I would like to be able to achieve it as shown in the lowest example.
Mike
See this tool in Mathcad Prime Minister:
http://communities.ptc.com/docs/DOC-2172
MikeArmstrong
(To:ValeryOchkov)
That is the sort of thing I am referring to. I really hope this gets implemented
Mike
All of this - this thread and several others makes me wonder... why does PTC not open the code so the users can make extensions to Prime? This won't solve issue like intelligent parsing or better text editing, but a lot of the other issues will be solved quickly by somebody...
MikeArmstrong
(To:SteenGroðe)
That's a very good idea, albeit one which I don't think PTC would be too keen about.
Mike
