Normalize eigenvec in MathCAD prime
ggoor
1-Newbie
I have attached my problem.
I need to convert the matrix to look like the "b" part. I get the "a" part correctly.
The operation is represented in excel file. I really dont know how to do it or if it is possible to do in MathCAD.
Really appriciate any helt.
1 ACCEPTED SOLUTION
24-Ruby V
(To:ggoor)
Can you please update my mathcad file with the solution?
Here you are.
I also added a way to create that function which does not need programming  (yellow) and so can be used in Prime Express, too.
Furthermore two ways to create the desired matrix U without using a user function "eigenVector" (blue, violet).
The last method would be the preferred way to do it in Prime as it does not call "eigenvec" twice.
11 REPLIES 11
-MFra-
(To:ggoor)
The eigenvectors are normalized.
ggoor
1-Newbie
(To:-MFra-)
So how can i get the matrix to be like the one i called "The correct value"?
24-Ruby V
(To:ggoor)
Looking for something like this:
ggoor
1-Newbie
(To:Werner_E)
Yes!
Even shorter
ggoor
1-Newbie
(To:Werner_E)
How do you write this in mathcad? i cant write the "<---"
24-Ruby V
(To:ggoor)
Its in the Programming menu and thats only available in the paid for version.
Are you using the free Prime Express version?
ggoor
1-Newbie
(To:Werner_E)
I use the paid version.
24-Ruby V
(To:ggoor)
Then you can find the local assignment arrow on the "Math" ribbon, area "Operators and Symbols"  in the "Programming" menu.
Find in my answer below the file along with a few other ways to achieve the same effect.
24-Ruby V
(To:ggoor)
Here you are.
ggoor
1-Newbie
(To:Werner_E)
Thank you so much! You are a lifesaver.
