Hi community,
I have a system equations 8x8, which I find its analytical solution with a approximation. I want solved numerically this system 8x8, but without this approximation. But I compare the analytical solution to numerical with approximation, and they aren't same. I used the command
linearsolve
this command has a error?, How many?
Thank you for your help and colaboration
mfduqued
Mauricio Fabian Duque Daza wrote:
Hi community,
linearsolvethis command has a error?, How many?
mfduqued
Your command is requiring a linear method for solution, some problems will not be solved using linear methods. Try a solve block; if "Find" does not produce a solution, try "Minerr."
Thank you for your time, How do I try solve a block?
Look up solve blocks in Mathcad help
Exactly what are you comparing to what? It's not at all clear in your worksheet.
>I have a system equations 8x8, which I find its analytical solution with a approximation<
____________________________
I won't trust that for a dime !
