I'm trying to use on odesolve command in order to create variables allowing me to graph Time v height & acceleration v time of a parachutist falling from stratosphere but I can't figure out why the it can't solve. Is it the equations? or is there a certain order I have to insert the odesolve? Any guidance is appreciated thanks.
What is the "c" in your initial conditions?
Try removing that.
Of course, it works perfectly now. Thank you
