One Way Ponding Solver
Maybe I will refine it and even will try to set some solution for (always simply supported) 2 way systems ponding.
A mostly academic issue, since ponding should be never a concern in properly operated stories since the deflection and loads should be limited in such way that no ponding effect is relevant.
I have formulated the 2 way ponding surface and it seems I did it still not of enough order, so failing equalization, so I will have to wait to one boring day or days to reform it for some new trial.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
