Optimization Problem
sm�ller-2
11-Garnet
Hallo community,
actually i have an optimization problem and want to aks if that is possible in mathcad.
For example if i have 8 input variables what i need to optimize and a few boundarys and a long calculation.
Is that possible within mathcad?
What good other program is there available? I have complicated formulas which are moore easy do write within mathcad because of the good mathematic notation and hard in other software like excel. But mathcad can only calculate on 1 cpu
The other problem is that i even dont know initial parameters for my variables to get a correct result so i need to exclude nonsense range of variables. I think i should be able to use a cpu cluster so i should be able to use more than 1 cpu fopr optimization problems
Thankx Stefan
14 REPLIES 14
Hi
Yes.
The free program Scilab can easily work the problem out.
Let the program work the cores not you.
Cheers
Terry
Try at first in Mathcad!
I hope we can help.
I have solved a lot of optimization problem in the field of mechanics.
Some of its is here
2^5 Problems for STEM Education
See please chapters with optimization problems
Study 8. Live kinematic schemes Or Arm of Hella
Study 20. Journey from home to school on the Fermat route Or The second optical property of hyperbola.
Study 21. Optimization of potential energy Or Curves of the second order in statistics
Study 25. Hybrid calculations on the computer Or One more about a cone
Study 26. Funicular Polygon in Static, Kinematics and Dynamics Or Isaac Newton vs Joseph Louis Lagrange
You can free download Mathcad-sheets from this site.
But if your problem is very... you must create own program with own algorithm...
can i run mathcad 15 optimization problems with like 20 cpus in a cluster?
I think optimization problems with like 8 to 10 input variables do need multiple cpus run
LucMeekes
(To:sm�ller-2)
Mathcad 15 (and before) is a 32-bit application that runs on a single core.
Ok thank you. Scilab also runs only on 1 core.
I think optimization with 10 variables on 1 core last ages.
Im able to use a cpu cluster so i need run optimization on multiple cpus but i dont know what software to use
It should be on GNU free license
Why not try Mathcad  on your problem anyway.  You will then see how it performs.
Perhaps outline the problem and let the community help.
Terry
LucMeekes
(To:sm�ller-2)
I.e. the community is becoming curious.
Luc.
Here is a Mathcad 15 sheet that maximises a difficult function of 2 values in very small time period.
We need to see this large problem with eight values.
Cheers
Hallo,
thank you for the file. Is it possible to define a certain step width for the variables which have to be changed in order to speed up calculation?
I do not know initial values for the variables in order to fulfill all side conditions. Is this a problem?
Thank you br Stefan
No.  The solver is a "black box".  It decides this.  You do not define a step width.
Yes, you must define a start value for all the variables.
Why don't you try Mathcad on your problem so we can help.
Terry
Not quite. We can use in Mathcad 15 the trace function.
See please animations here
Study 13 of the book "2^5 problems for STEM Education"
Thank you for the help,
i realized one optimization problem via MS Excel Solver. I used GPR nonlinear.
I came to a solution. But i dont know if it is a global solution.
The problem is i dont know the initial variables in order to fulfill all side conditions.
But Excel Solver came to a solution.
LucMeekes
(To:sm�ller-2)
Check out this, to see if it might help with your problem:
https://community.ptc.com/t5/PTC-Mathcad/Minimizing-a-Function-using-Simulated-Annealing/m-p/445213
Your Link doesn't work because somehow the characters "%A0" were attached at the end of the underlying link address.
It should be
Richard had also posted another one here
https://community.ptc.com/t5/PTC-Mathcad/Minimizing-a-Function-using-Simulated-Annealing-2/m-p/439802
Videos seems not to work.
EDIT: To make videos work I had to allow scripts from "brightcove.net".
