Optimization with Genetic algorithm
Emerald III
Optimization with Genetic algorithm.
Try pls Mathcad Server with your test function f(x, y) - http://twtmas.mpei.ac.ru/mas/Worksheets/Minimum.mcd
and see the picture:
PS I would like to create a video but sorry - no time.
Tags (1)
19 REPLIES 19
Re: Optimization with Genetic algorithm
One more solution with genetic algorithm:
http://twt.mpei.ac.ru/ochkov/Mathcad_12/3_31_Genetic_1.png
Hello!
Does this GA works for a 5-variable function?
Highlighted
yes
I guess the question (implicitely) also was if you would be so kind and share the worksheet 🙂
For most of us the Mathcad Application Server pages aren't that helpful.
Sorry!
See please the attach!
Tell please us is all ok for your function!
We will see if  Murarz  will come back and is able to use and adopt your sheet to minimize his 5-argument function.
See this thread
https://community.ptc.com/t5/PTC-Mathcad/Optimization-problem-using-minimize-function/td-p/592435/ju...
for the function he has in mind.
Hello!!
I am back ! I will try for sure, thank you 🙂
Thanks!
I am waiting your results!
Just one more question, xb, xe and yb, ye is the range (in this case for two variables) where the function looks for the minimum ?
