Optimization with Genetic algorithm
Re: Optimization with Genetic algorithm
xb, xe, yb and ye are for 2D problem.
There is a trick for 5D problem  too!
I know they are for 2D problem, just wanted to make sure what they stand for. I don't like tricks Smiley Tongue
Could you give me some clue? Smiley Happy I've been struggling with this and have no slightest idea where to even look for.
One method of the choking the minimum of the function of more than 2 argument:
From the figure I see you use minimize function. Does the same applies to the MGA ? Would be a possibility to send the file in xmcd ?
Sorry, I have not the xmcd-file. But you can create it yourself using the picture.
I can create it myself too - but...
Thank you Smiley Happy But can I this trick of yours apply to the 5-variable function for the genetic algorithm? I mean how should I specify xx,xn in this case since as you said it is for a 2D problem? To be honest I don't understand what you have achieved with this.
Was it about fixing 3 variables from the minimize function, and looking for other two from the genetic algorithm ?
