Out of memory error
bbobbs
3-Visitor
Out of memory error
I am using Mathcad 15.0 M050
I started getting an Out of memory error popup window, coming at random times when my MatchCAD file is open but not even running.
I added memory to my computer to increase its memory several times.
This did not reduce the occurrance of the Out of memory error at all.
Here are the errors that I faced
Out of memory
1 ACCEPTED SOLUTION
VipulT
(To:bbobbs)
Hi @bbobbs,
Try to use a different user profile for login and see if the issue persists. With this it can be narrowed down whether the issue is system specific or user profile specific.
Vipul
3 REPLIES 3
VipulT
(To:bbobbs)
Hi @bbobbs,
Please share the dxdiag report of the system having issues with.
To get the DxDiag report: Click Windows Start button > type “DxDiag” in the Search box, and then press ENTER > Save all information to “DxDiag.txt
Also, are you saving the file locally or on a shared network location?
Vipul
VipulT
(To:bbobbs)
Hi @bbobbs,
Vipul
bbobbs
3-Visitor
(To:VipulT)
Thanks!
