Outputting all program results
SOLVED
Newbie
I've attached a Mathcad 14 sheet showing Mathcad's Find Solver function being used to solve three simultaneous equations, although I could solve them by substitution. I also use a simple program to give me answers for different cases.
I would now like to output results for all the different cases, and plot these on a graph. Is there a way to output results for each of the different cases simultaneously?
Sam
Tags (3)
Re: Outputting all program results
Like the attached? I have called your solve block in the function.
I have also made your scripted component redundant.
I’m not sure what you the loads plotted against.
Mike
6 REPLIES 6
Mike
Thanks Mike,
This is good. I tried to use a matrix with the solver but didn't manage to get it to work, hence the scripted function. This is better, so thank you.
Sam
Thanks Mike,
No problem. Did you manage to get the graph sorted?
The iterating variable has to be passed to the Solve Block.
Mike
I am back on this again and do need to graph the results now. The problem is, I need to plot a line for each of the rows in the matrix below (against LC) This is a transpose of the answer in Mike's sheet that he attached in the earlier post, but I can't extract a single row from this matrix. I have tried a few different functions but am struggling.
Any help would be appreciated.
Many thanks,
Sam
I have managed to sort it by seperating then stacking the matrix as shown below.
Sam, hello!
Pictures that you attached to the messages are not visible .
