PDE Problem
Contributor
PDE Problem
Hey guys,
Now i'm trying to model the concentration in respect of time and space and that's why i'm using PDE solver. However why it does not work and it gave en error that "it found singularity while evaluating the expression.
Help please Smiley Sad((
7 REPLIES 7
Re: PDE Problem
Hi SavitriN,
it is better to simplify everything......The following  solution isn't tested:
Re: PDE Problem
Hi SavitriN,
the following is a revised and corrected solution.
Re: PDE Problem
Here's my simplified solution:
Alan
Re: PDE Problem
Thank you very much!
I will try that Smiley Happy
Re: PDE Problem
Thank you for the response.
Yes i will try this solution as well.
Cheers
Re: PDE Problem
The difference between the file 1 and file 2 that you sent is in the argument you put in the PDE solver. But is that affecting the result?
Because i'm trying your second file and it seems like it does not work again Smiley Sad
Re: PDE Problem
Hi SavitriN,
sorry, in the solve block the derivatives must be written in the compact form:
