PTC Mathcad Prime Worksheets Directory - Algebra & Geometry
TudorMarin
1-Newbie
Full list of worksheets
Full topic list
Want a free copy of PTC Mathcad Express? Download your copy today.
Worksheets marked with use PTC Mathcad premium features, otherwise they are Express compatible. All worksheets created in PTC Mathcad Prime 2.0.
Worksheet nameDescription
Complex Numbers in PTC MathcadThis worksheet using PTC Mathcad shows you how to work with complex numbers when using PTC Mathcad software.
Cubic Spline Interpolation
This worksheet helps to differentiate between regression and interpolation. Regression is a mathematical process that attempts to find a best-fit curve through a set of data. Interpolation allows you to estimate values between measured data points.
Eigenvalues and Eigenvectors in PTC MathcadThis worksheet using PTC Mathcad shows you how to use the PTC Mathcad functions "eigenvals" and "eigenvecs" to find the eigenvalues and eigenvectors of a matrix.
Random Triangles in the Unit SquareThis worksheet using PTC Mathcad supposed that three points are independently and uniformly chose in a unit square to determine a unique triangle.
Seeded Iteration in MathcadThis worksheet using PTC Mathcad shows you how to iterate through a variable based on an initial seed value.
0 REPLIES 0
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
