Is there a way to insert page numbers into a Mathcad 15.0 file? If not, is there a way to determine which page is which?
Kevin Glaser wrote:
Is there a way to insert page numbers into a Mathcad 15.0 file? ...
In main menu select "View" -> "Header and Footer" -> "Tools: Insert Page Number":
Kevin Glaser wrote:
...is there a way to determine which page is which?...
You can find the page number in the lower right corner of the program:
You can insert page numbers into the footer.
Mike
