Parameterized odesolve solve block?
rgunwaldsen
I am trying to fit data to a "First Order Plus Dead Time" model. I can optimize the fit by using the solution to the FOPDT equation, but, simply as an intellectual exercise, I would like to also be able to do this using the FOPDT differential equation. I have Python code that can do this (it takes an incredibly long time to run; I would guess that Mathcad would take much more time).
The nub problem of the problem as I see it, is that I think I need an optimization solve block to do the least squares fit which, in turn, then needs to call an odesolve solve block with parameters.
I quickly realized that I don't have a clue as to how to do this, and I haven't found any "parameterized solve block" examples that return odesolve solutions.
Attached are my Prime 6 worksheet, text file of data, and PDF of worksheet.
Many thanks,
Roger Gunwaldsen
1 ACCEPTED SOLUTION
rgunwaldsen
(To:Werner_E)
Thanks,  Werner!
7 REPLIES 7
Something like the attached?
rgunwaldsen
(To:Werner_E)
Thanks,  Werner!
FDS
(To:Werner_E)
Werner, would it be possible to attach your file as a mathcad 15 file or pdf? Thank you in advance!
24-Ruby V
(To:FDS)
Unfortunately there is no way to convert a Prime file to real Mathcad format.
Attached is a pdf print of the file. I only made the few changes to the original file that are highlighted in yellow just to show how the solve block could be parametrized.
FDS
(To:Werner_E)
Thank you!
rgunwaldsen
(To:FDS)
FWIW,   here is my final P6 worksheet which utilizes Werner's  suggestion plus a modified optimization to be able to repetitively call the odesolve block.
Shame on me!
In my sheet y.ode never changes and uses just the guess values!
I forgot to make y.ode dependent on the current values of K, theta and tau 😞
