Parametric design in inventor 2016 using PTC Mathcad Prime v3.1
elund
Hi, is there any way I can use PTC Mathcad Prime for parametric design in Inventor?  I use Win 7, inventor v2017, mathcad prime v3.1.
LucMeekes
(To:elund)
Just found on this page Mathcad Downloads that there are downloads for Mathcad 15 to integrate with AutoCad as well as Inventor.
Do not expect them to work with any version of Prime.
LucMeekes
(To:elund)
Hi Espen,
In short: maybe.
Longer:
Mathcad Prime is owned and developed by PTC, and apparently they intend it to be used with their own mechanical CAD software (Creo etc). They provide with Prime an API for integration with (other) software, but the Software Development Kit that explains (or, at least should) how to use the API costs a few thousand dollars.
There used to be an AutoCad add-in for Mathcad (not Prime), available via the download section. I know there's one that goes with Mathcad 11, but never actually used it. It may work with with Mathcad 15, and it may work with Inventor.
Note that Mathcad 15 is still more powerful in many respects w.r.t. any version of Prime, and you get it for free when you buy Prime.
VladimirN
24-Ruby II
(To:elund)
Currently, this integration is not available. There is only integration of Mathcad Prime 3.1 with Creo Parametric and SolidWorks.
LucMeekes
(To:elund)
elund
(To:elund)
Thank you all for your answers. I was expecting as much, but still hoped.
Brgds, espen
