Partially filled pipe flow
MBuck2
I constructed the attached worksheet for partially full open channel flow in a pipe using the Manning's and Colebrook-White equation, the problem is that the calculation proceeds as would be expected if the pipe diameter is 2 m but if one changes the diameter to be small or bigger than 2 m (change the highlighted yellow value) then the whole calculation gives very unexpected results and in some cases division by zero errors. Can some of the more learned users examine this worksheet and explain to me why this is the case?
Thanking you in advance.
Kind regards, Mark Buckton
In your definition of wetted area function P_w(r,d) in the d>r sectionyou had
P_full as 2 pi m - s_arc
should have been
2 pi r - s_arc
Mathcad was taking m as meter, so when r = 1 the equation worked
See please (the red formula) how we can work with empirical formulas!
Valery
Thank you for this insight, I was not aware of this work around for empirical formulas hense why I have given the normally unitless Manning's n units of m^-1/3/sec^-1. I will file your suggestion for later use. However this workaround does not answer the specific problem i.e. why does the answer "blow up" (as seen in the graphs) for pipe diameter values less than or bigger that 2m.
Mark
should have been
2 pi r - s_arc
Thank you f.kohlhepp this change has corrected the problem.
kind regards, Mark
