Phase Unwrap
heuserja-disabl
Phase Unwrap
I am using version 12 and cannot find the proper wording/equations to unwrap phase after calculating a Fourier transform. Is anyone familiar with spectral data handling regarding post-FT manipulations? Thanks.
See if this helps.
Thank you for the attachment - any chance you could define the process for me so I understand everything you did? And if I use this, how would you like it referenced?
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
