Pi and Prime numbers
1)
I know four Prime numbers from Pi without point.
Do you know more?
2) How we can find this numbers not manual - by programming?
3) It the problem correct and solved?
Your last number is only correct if you use rounded numbers. The last 9 is not a digit of pi.
I guess Mathcads symbolics will not allow us to find more of that kind of numbers. The float command is limited to 250 significant digits (which also means that I should have used 249 instead of 251 😉
You'll have to use a more capable program for further investigation, maybe good old Derive could be of help as there the number of digits is limited only by available memory (but being rather old I suspect it will not be able to use more than 1 GB). How about the abilities of Maple?
Remark: As Stuart has show with his attempts below, those routines will only provide numeric IEEE precision. So only numbers up to 15 significant digits can be found, no matter how large s is chosen.
it is prime 5
Can somebody open the sheet in prime 6 with new symbolic engine?
While the new symbolic engine allows values larger than 250 in the "float" modifier, it fails in the program if "s" exceeds 20 😞
The error message is "Unknown error: Integer_expected"
23-Emerald V
@ValeryOchkov wrote:
1)
Do you know more?
I've only got Mathcad Express, so symbolics and large numbers are not directly available.   However, it is possible to generate an arbitrarily long sequence of digits for pi by using a spigot algorithm.
I've had a quick play with one form of spigot and checked for primality using a basic factorization algorithm.   Unfortunately, I can only check 10 digits potential primes, so had to look up your 12-digit candidate (as Werner said, it's been rounded up by the symbolic processor from an 8 to a 9 in the last digit).
It would be interesting to know if the algorithm works with the symbolic processor.   It will (probably) need changing to create a list of numbers directly (rather than the string form I used for conciseness) so that the built-in IsPrime function can be used.
Cheers,
Stuart
I just gave it a quick try and the symbolic evaluation of routines like your "pi_gen" fail because of the use of the "if" command in "head" and "tail".
Redefining  p12list:=p12list= and then using the built-in Is Prime works OK, but of course the redefinition (actually already the conversion of the string to the number) limits us to the IEEE precision of the numerics.
The main problem is that "str2num" is a numeric only function and cannot be evaluated symbolically. So we are limited to 15 digits.
23-Emerald V
Thanks, Werner.  Have you tried replacing the string conversions with a multiplication?  For example,
where
piGen is unchanged but should return a numeric vector.
Cheers,
Stuart
From my future book!
Another mathematical problem that is also often used to compare computers and their software is finding large primes. This task is no longer empty fun - it has important practical applications in cryptography, for example. You can try to cross, as mathematicians put it, these two problems and find the maximum prime number of the form 314... Visitors to the site https://community.ptc.com/t5/PTC-Mathcad/Pi-and-Prime-numbers/td-p/677039 , on which the authors of this textbook posted this problem, found the first four primes forming the number π without a decimal point: 3, 31, 314159 and 31415926535897932384626433832795028841. In Figure an attempt was made to solve a modification of this problem: find the numbers π in the hidden “tail” (in the digital sequence following the well-known three digits 3.14).
The program in Figure, it was shown that within one hundred thousand characters of the number π in its "hidden" tail "there is only one prime number 104729 (3.141592653). And can you find an even greater prime number, if you go not up to a hundred thousand, but to a million, to a billion, a trillion, etc.? The question can be posed in another way: what is the largest prime number that can be found in the known set of found digits of π.
So, in the sequence of four million first digits of the number π (https://sanstv.ru/pi), the ten thousandth prime number 104729 (http://chemister.ru/Other/Text/primes10000.htm) is found only once. But there you can find another larger prime number 333667. This (the largest prime number in the sequence of digits of the number π) can be a new interesting task for testing both supercomputers and programmers who create programs for them.
As I have written above, all numbers for "s" above 28 yield no usable results, because the symbolic evaluation of the "trunc" command yield wrongs results. So unfortunately it does not make sense to let the loop run up to 100000.
This was the reason the program I posted in my first answer did not find the 38-digit prime. With Stuarts program it was able to find that number.
The next prime number (I am only speaking of the digits of pi beginning with 314...) as can be seen in Stuarts post will have 16208 digits. According to the speed measure I did so far and depending on the model we chose for prediction, Stuarts routine wold take 5 days up to a couple of years and its not sure at all if his program with Mathcads symbolic would be able to find and display that large number.
As Valery already said - its the wrong place here!
You asked the same question twice in midst of two threads which both have nothing to do with your question! Please avoid this for future questions.
https://community.ptc.com/t5/PTC-Mathcad/Defining-an-equation-with-range-varibles/m-p/677996/highlight/true#M191011
To open a new thread with a question concerning Mathcad or Prime, go to
https://community.ptc.com/t5/PTC-Mathcad/bd-p/PTCMathcad
and then click "Start a topic".
We are searching
My know-how!
