Piecewise Function
Marble
Piecewise Function
I need help in creating a piecewise function for  the black function so that it starts at  the red point and ends on   on black and i want to create a loop for the black function to do this every 2*pi/N degrees please help.
8 REPLIES 8
Highlighted
Re: Piecewise Function
Cheers
Terry
Hey I couldn't open.
Could you please send xps of this so I can see the entire file?
Hi
What version of Prime are you using?  I have enclosed a pdf.
The only new stuff  at the bottom of your file is this:
Re: Piecewise Function Prime 4
Prime 4 Enclosed
This wasn't what I was asking for.
I was asking for how to make the blue curve stop on black and make a circular pattern/array of the current blue curve.
Here's a brute force approach for what you were asking for.
Not sure if it makes any sense, though.
Worksheet in format P4 attached
The word 'blue' does NOT appear in your original post...
How certain are you about what you are asking for?
Luc.
2D and 3D stars
