Plot 2D slice view of any angle
sfan
I have a 3d plot on an rectangle range within x-y,
I want to have a 2d slice view of the diagonal.
Is there a way to achieve this ?
StuartBruff
(To:sfan)
There are several possibilities. Possibly the most straightforward is to create a special variant of your uh function that accepts only one parameter and returns the x, y co-ordinates on the diagonal and the value of uh, for those points. Then use CreateSpace to plot this function.
Stuart
Hi, Stuart,
I am running the 3.0 version and using the educational license.
Is there a way to open your file with 3.0?
Or could you please screenshot your process of creating the variant function of uh?
Thank you for your help!
Shawn
StuartBruff
(To:sfan)
You don't actually need CreateSpace to just plot the function ...
Stuart
