Hello, can anybody help me with plotting these values in Mathcad se picture.
Like this?
If you want the other graph, you will have to provide the expression for the Gerber parabola.
is it possible to make it a little more presentable ? Like this maybe:
Hi Kenan
To find more adjustment in a plots features you need to use the chart component new in Prime 6.
The plot component is found on the menu Math | Regions as a drop down list.
One is enclosed in file attached. Double click it to activate format options.
The plots--sure! 🙂
The labels--well, you're on your own.
