Hello Everyone.
Plotting local max-min-points ?
Thanks in advance.
@lvl107 wrote:
Could you attach *.xmcd ? ( I'm afraid I may hit wrong key stroke... )
Best Regards.
Hmm, really!??
Here's a slightly different approach:
Unfortunately the more direct and logical
does not work in Mathcad - muPad is not capable to find the solutions.
Set a function that is the derivative of f(x).
Use the root function on this derivative within a range to determine unique roots.
You now have enough info to plot the points.
Many thanks both of you, Valery. And I still have a query : "How to prove what point is local min-point ?
Best Regards.
Best Regards.
AWWW! C'mon!
Best Regards.
Hmm, really!??
Some basic calculus (see Werner's application):
In case of this function Mathcads symbolics is capable enough to give you al solutions, so you should use it.
If your goal is to limit the results to x1<x<x2 you may use the "assume" modifier.
