Post Formatting
MikeArmstrong
Post Formatting
Does anyone know if the default font and settings can be changed?
Also, is there a way to set a signature up?
Mike
6 REPLIES 6
Mike
Have you investigated template files? Insert and change what you want, then "save as" a template (.mct) file.
I'm talking about the forum posts, not Mathcad worksheets.
Mike
Mike,
Did you want a font outside of the 15 or so that's provided from the font drop-down?
-Dan
Mike,
-Dan
Dan,
I wanted to change the font of my posts and add a signature.
Mike
Within the Text Editor, choose a different font from the drop-down menu. If the 15 choices isn't to your liking, you can use HTML tags to define the font you want.
No automatic way to post and attach a signature. You'll have to copy and paste text from a handy text file saved to your desktop or create an image of your signature and insert it as a picture.
-Dan
But each time I post I have to manually change the font. Is there no way to change the setting permanently
Shame, but not that much hassle
Mike
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
