Does anyone know how to add a title to a plot in prime 3.0? Add a legend or even label an axis? From my searching it seems these features are no longer available in Mathcad Prime. Also, I can't believe there are only three settings for the document margins! In the previous version of Mathcad I used (v14) I was able to customize the margins. Am I missing something here?
You can't.
Pathetic, isn't it.
That you should stick with MC15, and just not use Prime?
You can't.
Pathetic, isn't it.
Thank you.
should read, "were never available in Prime."
