Prime 5.0 Express Define Unit?
SOLVED
ndziedzic
Visitor
Is it possible to define custom units in Prime 5.0 Express?  I have a drop down in Math Formatting and unit is there and not greyed out. However, no matter how I try, I cannot change any variables to the unit format. So I started to think maybe this is not supported in the Express version.
Tags (2)
1 ACCEPTED SOLUTION
Re: Prime 5.0 Express Define Unit?
Now it is working. You need to define it as a unit.  Highlight it.   Then go to Math | Style | Label | you get to choose what it is
Cheers
4 REPLIES 4
Should not be a problem, even in Express. Attach worksheet. ..
Thanks for the reply.  Worksheet attached
Cheers
Thank you,
I was going under the Math Formatting menu and trying to change it there.
Really appreciate the Help.
Norm
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
