Printing a page with an embedded Adobe File
pdorvel
On several occasions I have found it useful to insert an object for reference in a MathCAD document.
However and despite pains to size it right, when I print the page with the object it shrinks to a miniscule
icon. What I see in the living MathCAD document is a full size view of say a transmission line structure
with dimensionos. This is also what I see when I do a print preview. The objects I insert have been Acrobat
pdf files. Should I use a different type of object? Is there trick I am missing?
FredLusk
(To:pdorvel)
I have never tried to insert a .pdf file into Mathcad, but I will have to give a go. Normally when I need an image of or from a .pdf file (for whatever reason), I simply load it into Acrobat, click File | Save As | Image, then choose what image file format I want to use.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
