Problem (BUG) in Chart Component Logarithmic Minor Gridlines
vyerokhin
Regular Member
The Minor grid lines and Tick Marks do not appear at all when using Log scale. This seems to be a bug. I do not know how to submit a bug report, so if anyone does - please submit one. Looks like everything about Log scale under Chart component has not been QC’d.
I'm using the latest Mathcad Prime 6.0, but I believe this problem will also exist in Prime 5. If so, I can't believe this has not been caught during the last 2 or 3 years that they've put a lot of "focus" on graphing
There is also very limited control over the Log plot scale, and sometimes, when playing with Minimum and Maximum under User-Defined Range, the scale displays something completely weird - as shown in attached screenshot. This is probably also a bug.
Re: Problem (BUG) in Chart Component Logarithmic Minor Gridlines
You're using the wrong plot tool, this is Prime 4 but the same is shown in Prime 6:
Note that the plot tool that was added in Prime 5 is a third-party component. It has other quirks besides not showing tick marks on log scales.
Unfortunately the native Prime plot is not able to add gridlines unless you create them on your own like shown here.
The third party chart module which was added in Prime 5 sure is suboptimal in many ways and its also poorly "blended" into Prime.
I would not have too much hope that reporting the various bugs and drawbacks to PTC would be of much help.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
