Problem Static
SOLVED
Level 8
Problem Static
Good afternoon group friends, I am a beginner in Mathcad, and I am not able to finish a static problem, if you can help me, thank you very much.
Re: Problem Static
What did you expect? You have not defined x and y so you cannot expect a numeric result.
You may let Prime evaluate symbolically, though.
15 REPLIES 15
Re: Problem Static
Welcome to Mathcad.
Due to PTC's greed, since you are using Prime version 5, many of us cannot see your problem.  Consider posting a picture version as well.
Re: Problem Static
ok
Re: Problem Static
Follow the file in jpg
Re: Problem Static
Re: Problem Static
Werner, why the final answer did not show in "m", what I'm missing here. If you had to solve this problem through vectors would you do the same thing I did?
Re: Problem Static
Re: Problem Static
That is due to your definition. You defined rp as rp:=[x y 0] m. This means that x and y, like 0 are just numbers, without units. I would be rp that contains x m, y m and 0 m.
If you're interested, you might try to find out what happens if you define rp as rp:=[x y 0] and then solve x and y.
Re: Problem Static
Thanks LucMeekes, but I did not quite understand the answer, rp = [x y 0] m is different from rp = [xm ym 0m]. I used it the way it said and it did not work, could you please give a practical example.
Re: Problem Static
Attached is Prime 4 file, readable with 5
