Problem Static
SOLVED
Re: Problem Static
Thank you Fred that's what I needed, clear and perfect explanation.
Re: Problem Static
Sorry to nit-pick, but I think Fred has a sign error.
Re: Problem Static
Sorry, Prime 5 worksheet. PDF attached.
Re: Problem Static
Thanks for pointing out my error!  (See the attached sheet for a long, devious correction and reason.)
But your solution also has an error:  cross products are sensitive to order; both your solve block and your check have the order reversed
should be [-0.114   0.2   0]
Re: Problem Static
You're right, as usual, Fred. I need to go back to school!
Re: Problem Static
I ALWAYS have to check. . .   Smiley Happy
