Problem displaying 1000 lb = 1 kip
aaaaaaaa
6-Contributor
Why is it that whenever i type 1000lb equals to i get 0.102 (s^2/m)*kip, while i want the output as 1000lb=1kip. Why is it that I can't get a simplified answer in kip or something other than a fundamental unit including acceleration.
Thank you.
1 ACCEPTED SOLUTION
LucMeekes
(To:aaaaaaaa)
Welcome to the wonderful world of units.
You're trying to compare a force (kip)
with a mass (lb)
The gravity constant (g)
is in between them.
You may want to compare kip with lbf...
2 REPLIES 2
LucMeekes
(To:aaaaaaaa)
with a mass (lb)
is in between them.
aaaaaaaa
6-Contributor
(To:LucMeekes)
Thank you so much!
