Dear Expert,
i'm working on an equation relates to the differentiation in a range of value.
The problem is i could not get the result for each value within the range unless i manually insert it.
here i attached my working spreadsheet for better understanding.
Appreciate your help and guidance.
Thank you
-Akmal-
As Werner wrote:
You will have to vectorize your expression:
Also, you could define r(X) more succinctly, and predefine your derivative functions too - see attached.
Alan
Thank you very2x much Werner and Alan.....
That simple yer.....so much more for me to learn in mathcad....appreciate more on your assistance later.
