Hello erverybody,
I want to open a *.xmcd-file (which created by Mathcad 15) in Mathcad Prime 5.0, but failure. PTC Mathcad Prime 5.0.0.0 XMCD, MCD Converter can not convert too: error message is "Mathcad 15 M010 or higher is required to run the converter.".
And after each converting, I must restart the converter. Is it normal?
I used the data in xmcd converter as exercise, but converting was also fail.
Could you tell me what are the reasons for the two question above? Thanks for your antworts.
Best regards
Sun
For a download of Mathcad 15 see here: https://community.ptc.com/t5/PTC-Mathcad-Questions/New-service-release-of-Mathcad-15-M050/m-p/554723#M181000.
Yes! Thank you Luc!
Sorry, I thought the converter could run without MC15.
After MC15 was installed, all problems are solved. Thanks again.
BR
Sun
