Problem with Excel component being "busy"
Highlighted
Newbie
Hello everyone
I've had the same problem as descripted here twice this week:
Unable to activate Excel component
I work with an embedded excel table which contains a function. At a certain point I get the error message "Excel is busy; can't activate Excel. Make sure that cells are not being edited in Excel and try again in a few seconds." but there is no instance of excel open. Upon restarting mathcad and/or my computer the problem remains.
Does anyone know how to solve this problem?
Could someone please check the appended file so I can exclude an error of my sytem?
Cheers!
11 REPLIES 11
Highlighted
Re: Problem with Excel component being "busy"
What version of office are you using?
Mike
Highlighted
I am getting the same error message and using Office 2013. It seems the worksheet has become corrupted somehow.
Your Excel component seems to have an image inserted? That might be the cause. I have embedded a new Excel component into your worksheet and it works.
Mike
Highlighted
Thank you for checking, I'm also using Office 2013 and Mathcad Prime 3.1
There is no image in the Excel component...
I think i will try to file a Bug to ptc
Highlighted
Maybe worth a try. Did you manually input the data shown below?
You could try and replicate the problem in a new sheet.
Mike
Highlighted
Yes I just opened the component and entered the data?!
I've got a backup file which is still working:
Highlighted
Very strange.
Mike
Highlighted
I have the same issue by using Mathcad Prime 3.1 and Excel 2010 on Win7 32-bit.
Highlighted
What about if you insert a new Excel component?
Mike
Highlighted
Inserted properly and clickable.
Highlighted
I am experiencing the same problem. I have no working excel components and the back-up sheet posted below in the thread did not function. No open instances of excel. Was a resolution found?
Using Mathcad Prime 4.0 and Office 2016.
Highlighted
You use Mathcad Prime 4.0 M010 service release?
