Problem with columns and vectors
SOLVED
Bedrock
Hello
as in the Monte Carlo simulation in the help (step 7), the columns with the variable i are separated into vectors.
How can I just get the positive or negative values?
Example: From this column I only want the positive or negative values.
I use Mathcad Prime 4.0
Re: Problem with columns and vectors
a short program:
a short program:
You could also use a combination of "match" and "trim".
Thank you
